Navien replacement
SDG
British Columbia
Hi there,
I have a circa-2008 Navien CR-210 water heater that is having more and more intermittent issues as time goes on. I think it’s getting to replacement time. I do have a recirculation line in place.
Would the likely replacement model be the NPE-210A2? I’ve read about these newer units having some exhaust gasket oily leakage issues (https://terrylove.com/forums/index.php?threads/if-you-own-install-or-service-navien-equipment.94431/), would that be an issue for the unit I’d be looking at or is it resolved? If it’s a problem, is there another unit that would be similar enough to swap in (ie: similar fittings and locations)?
