Navien NPE-240A2 Recirculation plumbing
Stlgasman
St louis
I currently have a Navion with the Navicirc valve. It works. Sometimes it whines. The negative is that when you switched back to cold water it takes a long time.
How would I plumb in a dedicated recirculation line? The hotline is on the left and the cold line is on the right.
There is a dedicated recirculation line which is next to the hot outlet. It has a black plastic 3/4" cap. That is the line.
You will need a plumber, obviously. There is also a setting adjustment to make.
