Not being a jerk, just explaining why I was confused at the answers I was getting. Don't be sensitive...if you installed an A2 board it has a port for the VID sensor. If nothing is plugged into it then it thinks no exhaust vent is installed. So you either need to install the correct board or the A2 collar with the sensor. I would do the correct board if it was me. Where are you getting parts from? Navien does not sell online except through authorized retailers and you usually have to be a contractor. Installing parts purchased from unauthorized sources voids all warranties. This is also why Navien prefers to have work done by licensed trained technicians I.E. so that the trouble you are having from installing the wrong part doesn't happen. PCB part #30011969A
