Hello,
I recently updated my aging NR240A with a NPE240A2, and immediately it was a better experience. Water heats faster at fixtures, the fan noise is significantly less, principally in the 'post-purge' phase.
After about a week of having it installed, i decided to create a dedicated hot water recirc line to take advantage of the ComfortFlow pump(i have other construction going on that made it easy). I tied 1/2" PEX :donthurtme: into the 1/2" copper lines in a kitchen and a bathroom and brought them down to the heater. This is the little manifold i made (a check valve on each recirc branch and then one before it goes into the heater)
I am 99% sure i configured the unit properly, its on external, no external pump, intelligent mode, valve is open to EXT.
The recirc does seem to be flowing, both branches are warm to the touch at the manifold, and at the tie-in near the fixtures are. However, i immediately noticed that when i am taking a shower, or using a lot of hot water in the kitchen, i have these big swings in temp, and it doesn't seem to get as warm as it did, even if i go full hot.
Hoping you all can provide me with some more ideas for debugging, or point out possible mistakes in my design.
I am using Intelligent mode, so it will be watching my use for the next 7 days (maybe i just need to wait for it to settle?)
I do have ball valves on each recirc branch, so i can try to balance branches.
Is it a problem to have the recirc in a 1/2" PEX? could it be not sucking enough volume through that diameter? (The 3/4" in the pictures is only present for about 6 ft before it goes into 1/2" copper, which is what is run throughout the house)
Do i need to tweak temp settings on the unit?
Thanks again,
DIY Dave
Thanks again,
DIY Dave
