Hi,
I have a Navien 240a that has started shuddering and shaking when under full load running the bathtub. No error codes. In taking the cover off, it’s clearly an issue related to the intake air, almost as if it’s gulping for air and quickly starving and recovering several times a second. Cover on or off makes no difference. You can see this when looking through the viewer at the burner as well. Oddly, if you just place a finger or other slender object above the intake and disrupt the air flow, the shuddering and shaking and noise all stop and it sounds normal. This is right above the actual intake with the cover off. What I don’t know is if by placing something in the air flow path it is disrupting the flow (ie laminar vs turbulent) or if when you do that, the controls are somehow compensating something else that causes it to smooth out. I can certainly call a plumber, but I’ve had mixed luck in the past with their experience on this unit. I’m a mechanical engineer so technical troubleshooting isn’t an issue if the experienced folks on here have any ideas.
