Freedomeagle
I have the above Navien and want to install the NaviCirc recirculation valve. Two questions. First, I understand I will need an external recirculation pump. What is the recommended recirculation pump for this model of Navien? Second, its in a new, single level home. It is approximately 100 ft from one end to the other. On one end is a seldon used guest room, the master bath is on the other. The water heat sits about 30' from the guest room end and the kitchen and laundry are about 1/2 between. Can/should I use two valves, one at the guest room and and one at the MB end; or can I only use one valve. Thanks in advance for your help with this.
