Jac04
There are actually 2 adjustments on the unit. There is a 3rd stage MIN and a 3rd stage MAX to adjust. It is all outlined in the manual. If you know what you're doing, make a u-tube manometer and do it yourself. You will probably be able to get the unit "dialed in" better than most 'professionals' (because it seems like most professionals aren't that familiar with these Navien boilers.)
However, BEFORE you make any adjustments on the unit, make 100% sure that the gas supply pressure is within spec. Don't just look at static pressure with the unit not firing, watch dynamic pressure as the unit fires. Using a u-tube manometer makes this easy, as a digital unit doesn't really let you see what's going on quick enough. Mine looked good static, but the original 2-stage regulator could not keep up with required gas supply when the unit fired.
After getting my gas supply issues taken care of, my unit seems to run quite nicely, BUT....
Every now & then, only when firing for heat, the unit will ignite, and as it ramps up it will loose flame, fire again and then stay firing. It's weird. My max firing rate is set for 35%, maybe that has something to do with it. It's almost like the fan overshoots the max firing rate, causing it to go lean and flame out.
Here's some other interesting facts, according to the Operation Flow Chart in the Service Manual:
You need flame-out within 10 seconds for 3 straight times to give you the 003E Ignition Failure error.
You need to loose flame 20 straight times during normal burner operation to get the 012E Flame Loss error code.
