Landcrabmech
First off, I am a multi certified trades-person in Canada (4 Red Seal) designations. Plumbing is NOT one of them, hence I am here to ask a couple questions to the knowledgeable plumbers on here.
I am removing my HW tank and Mini Super Hot boiler and replacing with a Navien CH240. I have 2 zones in my home, 1 upstairs and 1 main floor of radiant floor heating. Both floors are approx 600sqft.
Question 1- Do I need a Navien manifold for the floor heat?
Question 2- Can I just have the internal pump supply the water to the floor heating loops or do I need a separate external pump?
Question 3- Relates to question 2, I have 1 thermostat down stairs and 1 upstairs to control temperatures. So I guess my question is if Zone 1 upstairs calls for heat, will the Navien kick on to supply heat to the upstairs floor? And same for downstairs.
I have 2 thermostatically controlled valves with the SuperHot boiler, so I kind of want the same set up.
One reason I am installing myself is that the first plumbing company quoted almost $10,000.00 for the install and now the second has quoted 45-5500.00. Seems quite high since I already Own the Navien, Have it hung where I want it, Have the intake and exhaust pipes already run and hooked to the unit. All that needs to be done is to hook up the floor heat part of the process and the DHW part of the process. The NG is already in the room where the boiler is so there is no modifications needed to the 1/2" gas piping. I will be using "Gastight" hose to run from the gas valve to the unit.
I have installed and am certified to hook up natural gas and do natural gas conversions on vehicles and I know the household is very similar.
Cheers and thanks in advance for any advice you might share.
If you post negative things about what I am doing, that is your own prerogative. I will not judge you.
Thank again.
Scott
Vancouver Canada
Thank again.
Scott
Vancouver Canada
