Toronto123
I purchased a house last year that has a Navien CH240 combi boiler feeding the house rads and hot water.
The rads are cast iron and the navien is relatively new (3 years old). I am having never ending issues with this unit. I had to have the main circuit board replaced and as part of a basement renovation, I had my plumber remove the rads. My plan is to move the navien and a company who specializes in tankless units told me the navien is not intended for my house since it wont work properly with cast iron rads and the iron piping i have. He said i really need to replace the unit completely unless we install some sort of additional filtering to clean the water - otherwise he said the unit likely wont last a few years at most.
Since we removed the rads i now have no hot water - we have an E002 error which is low pressure. Im thinking air must have got into the pipes when we removed the rads. However, the heating company is saying they told me the unit wouldnt last and is recommending a full replacement of this relatively new unit.
Question 1: Can anyone confirm that a Navien can or cant work with cast iron rads and iron pipes?
Question 2: Is it possible this E002 is just caused by an air pocket in the pipes.
We know the install of the navien is not correct as it doesnt have a secondary loop, a secondary pump as its supposed to - im hoping a proper reinstall of the existing unit will be sufficient rather than a costly full replacement and im looking for input from anyone who can answer my above 2 questions
Thanks
Thanks
