Internet search led me to this forum and a few posts about what I'm currently experiencing. I had a Navien 240A installed about 2 weeks ago. I have a PEX recirculation line that goes from my unit to the copper pipe to my kitchen sink hot line.
Every once in a while when taking a shower the water goes from hot to warm and stays on the warmer side. I was not sure if this was normal for a tankless so we basically thought we would have to live with it. Once I found this forum I know this is not normal.
I opened the panel and confirmed that the unit is set to ext recirculation, DIP 1 of off and 2 is on. Tonight when I get home I'm going to set it for internal recirculation and set DIP 1 to on and 2 to off. If that fixes the problem I will know its probably the ext recirculation line that is the problem.
Sorry that this is so wordy but here's my questions. I have a shut off on the PEX line but no check valve, so if putting a check valve in will help my issue where do I put it? By the unit or the Tee of the copper line. Since its a PEX line can I just use a shark bite check valve. And if I just decide to stay in internal rec mode and bypass the rec line, what happens to the water just sitting in the line?
Thanks
Thanks
