Navien 240A compatible with NR-21DU?
John DC
Kansas City
Hello,
I have an NR240A which was installed in 2020. I was able to add external recirc and an external pump without a problem using the Parameter list and the dip switches. I purchased an NR-21DU to add a timer to my recircluation.
I cannot get it to communicate properly with the 240A. It allows me to change the temperature, but is 20 degrees high (120 on the 240A shows 140 on the NR-21). I can't get recirc to work at all. I have tried connecting it while the heater is on, while it's off, and even while power is disconnected.
Any parameter settings I am missing?
Q
Quark
Guest
Navien tech support told me that NR-20DU works with the 240A and that the NR-21DU works with the 240A2.
