Chris needs help
OK, I can't believe how difficult it has been to find information/know-how regarding what seems to be a very straight forward problem / solution.
My current NG supply is 6 wc, which after making appliance additions to my residence now is inadequate (current demand is 400 BTU max for 6 NG appliances (Furnace, Water heater, Fireplace, Grill, Dryer, Stovetop). If the furnace and water heater are running, the grill won't light. Incredibly frustrating. Solution: More pressure or repipe with larger diameter pipe. The smart money is to increase pressure. Fortunately:
My NG provider is willing to up my PSI output from the meter to 2 PSI (54"+ wc), but first I have to install a NG regulator to bring it down to .5 PSI output. I would prefer to install one regulator on the main line (1") from the meter to bring the pressure down vs. separate regulators for each appliance (seems silly and unnecessary work). Question: What is my solution? Specifically, what regulator should I install on the mainline?
Reminders:
I know this has to be an easy solution, however the local "pros" have been unable to provide any reliable guidance. Straightforward responses will be incredibly appreciated.
Thanks in advance for time/advice.
Chris.
Reminders:
- 1" line from the meter. I would like the regulator to be inline 1" in and out.
- If regulator is installed in the main line, it must be able to support 400,000 BTU with 2 lb pressure in and 11-14 wc out.
- The longest line from the meter is 100'
- All branch pipes are 1/2"
Chris.
