Mysterious clog in kitchen sink
cynthiap
Arizona
Hello,
I have a kitchen sink that is clogging on both the right and left sides. I'm a woman and I don't know the correct terms for all the plumbing, however, I do know how to take apart the plumbing under the sink and put it back together and how to snake the pipes.
So I took it apart at the (trap) and the trap had some stuff, but not clogged. I cleaned it up. I have a little plastic snake about 24 inches and ran it from the right side of sink down and could see it come through at the bottom, and ran it upwards as well. I also took the piece of plastic pipe that connects the main metal pipe going down into the ground apart and it also had some gunk but not clogged. I cleaned it out as well. I ran the plastic snake down the main metal line as well and it wasn't clogged in that 24 inches and very little came out on the snake.
While the trap was removed and I had a bucket under the pipe, I ran water down both sides of the sink and it is coming through into the bucket on both sides. Seemed to be working fine. So, I put everything back together, but it still keeps clogging. It drains out eventually, but very, very, slow. And sometimes it is more severe than other times. Sometimes it takes forever to drain and sometimes it moves quicker, but not quite normal.
I don't understand. All the pipes are clear, the water flows through into the bucket when the trap is not on there, but when the trap is put back together it all appears to get trapped before it makes it to the trap. Because I fill up a 2-quart size pan and pour water into the sink on both sides, and the right side clogs with only 1 quart of the water, and the left side clogs with the full pan of water, so it isn't making it very far down the pipe before it clogs. But there is no clog in there. The snake goes through it. Any ideas on what the heck is going on here? It makes no sense. Would appreciate any thoughts you may have.
I don't think the issue lies in the pipe going out of the house, because of the fact that it only takes a quart of water before it clogs. It appears the water is getting hung up at the point where the left side of the pipe and the right side of the pipe intersect. But there is no clog there. So how could it be getting hung up there?
I have a bigger metal snake that I could run through the pipe going out of the house, but I just don't think that is where the problem is and don't want to waste the time and energy. And I'm a little afraid to try that.
The second issue - I poured lots of hot water down the drain to clear the clog before I took it apart. Sometimes that does the trick, but it didn't this time. It helped but didn't get it all. The hot water loosened the seal of the little plastic fitting that goes against the metal right at the base of the plumbing where the plastic pipes all connect to the sink. I don't know what that is called. It's a little round plastic piece it goes right up against the metal of the sink and then the plastic pipe screws over it. I've had to replace that little plastic fitting before after I ran hot water down the pipes before. So I knew how to do it and I had a spare one in case it ever happened again. So I replaced that little plastic fitting. But now the piece that screws over top of it (I think it is called a nut) and on to the metal sink is not tight enough. I think the nut might be stripped. I can't get a tight seal. It's leaking. I don't know how to get that nut off of there, it is attached to the middle plastic pipe and won't slip off. It appears I would have to replace the entire plastic pipe in that area. Is that correct? Or is there a way to get that nut off of there and replace just the nut?
Thank you.
Cacher_Chick
Test, Don't Guess!
You need a longer drain snake to go down the pipe further. The drain might go many feet before connecting to the larger pipe that drains the whole house.
cynthiap
Arizona
Thanks for your response, but that doesn't make sense, because as I explained above, the sink plugs up with 1 quart of water. The water isn't even making it down to the trap. When I take the pipes apart there is no water in the pipe leading out. It's clear. The water is trapped in the upper part of the plumbing.
One quart of water will fill 2.72 ft of 1.5 inch ID pipe. The drain tubing for your kitchen sink is a little under 1.5 inches ID.
