Casecapital
Hello,
I'm replacing our water heater.
STRANGE - before I removed the old water heater, I touched the two flex hoses attached to the top of the water heater. There was a copper pipe that came out of the left side of the wall (that did not have a shut-off valve attached to it, until I put one on)....and this one was attached to the top left of the water heater (which said "HOT" next to this nipple). However, when I touched it, it was cold.
And the copper pipe that comes out of the right side of the wall (that did have a shut-off valve attached to it by the plumber that replumbed our house when we renovated 10 years ago)...and this one was attached to the top right nipple on the water heater (and it said "COLD" next to this nipple). But when I touched this one, it was definitely hot.
So, it is like the plumber did everything in reverse. It is like he planned on having the copper pipe on the right Side be the cold intake, (that comes from the street) and that is why he put the shut-off valve on that one and attached it to the top water heater that said "COLD" next to it.
However, as I said, when I touched that one, it was hot to the touch, and the left one was cold.
I didn't think too much about it (other than he hooked up the gas water heater in reverse). But then when I put the new electric water heater in, I can't get anything but warm water at best to come out of the warm taps in my sinks/tubs.
So then, I drained everything and decided to "Test" which of the 2 copper pipes coming out of the wall is the "true" cold water line coming from the street.
And here is what happened:
FIRST - I disconnected the cold intake and hot out-take.
I got to the point where I had both the cold in and hot out disconnected, and a new valve on the cold intake (so I can turn it off and restore at least cold water to the house).
But here's my huge problem:
If I leave the cold water intake valve open and turn on the water to the house again, cold water comes pouring out of the cold intake pipe as you'd expect.
If I then close the cold water intake, water then starts coming out of my hot water out take!?
It appears that my cold water line and my hot water line in my house are linked or intersect somehow? I know that when we renovated the house, they had to move our water heater from the left side of our house to the right side of our house and put it in the garage. And I do remember the contractor saying something about the plumber having to "reverse" the plumbing to get it to work correctly, but I had to idea what he meant. That was 10 years ago, and we have always had hot water, until the water heater died of age recently.
Do you think that my main cold water line, that come from the city street and feeds my house, is somehow attached or linked to the hot water line, so that they "mix"?
Any thoughts would be greatly appreciated!!
Thank you!!!
Thank you!!!
