CountryBumkin
Active Member
I have a well that is around 300 ft. deep (I think). The submersible pump is over 27 years old now. It makes a loud clunk/bang when it starts. It has a 40 gallon pressure/bladder tank.
Should I replace the pump now - before it fails? What is the expected life of a well pump.
I am the original owner of this house. Four bedroom ranch in central FL. There are just two people in the house. I don't know what size/HP or GPM of the pump is. Is there any way to figure out the HP size without pulling the pump?
I would like to go with a "Cycle Stop Valve" setup.
If you don't recommend replacing the pump now (just wait for it to fail), can I just add the CSV now - or should I wait until a new pump is installed?
I think the CSV would help because I have front yard and shrub sprinklers (five zones) that makes the pump cycle on once about every 5 or 10 minutes and the sprinklers run for about 2.5 hours every three days. I haven't had the sprinklers for all 27 years - I just installed them a few years ago. But that's a lot of pump cycling I think. I suppose could add more sprinkler heads to keep pump running longer - but wouldn't a CSV be a better solution?
Thanks
Thanks
