frank in ohio
In remodeling a bathroom, I was at the point of replacing the shower. I bought an E.L. Mustee shower pan (36 x 36). The drain is in the middle, as was the old one, but rather than being just a hole, there is a sort of built in drain that extends down about 2 inches or so. The directions say to simply insert the 2" pipe from below, then press in this donut looking rubber thing from above (after applying some sort of lubricant), and all will be well. This just seems that it will be subject to leaks. I have a friend who has replaced a shower before, and said that his drain was just the hole in the center, and that he had a piece underneath with threads that the 2" pipe went in to, then the top drain threaded into it with a rubber donut in between that gets compressed when tightening up the drain. Seems better to me. Does this Musteee setup without threads actually work?
thanks in advance
frank
thanks in advance
frank
