Hi guys new-by here, I had a well drilled at remote cabin last summer in idaho. Driller hit water at 200 ft but we went extra 20 feet so total well is 220 feet drilling through decomposed on top and then granite. Getting 4 gallons a minute and static water is 28 feet. Casing is six inch metal first 60 feet than 4 inch pvc to bottom. I put in a 3/4 horse 5 gpm pump at 195 feet on 1 inch poly. Im pumping to 40 gallon pressure tank in cabin. Tank is set at 40/60 to turn pump on and off. We let water run out side till it cleared up then plumbed into house. we only use this every other weekend or so, The water is murky and will plug filters over the week end. using 3 4x10 filters. It is not coarse sand it is like silt real fine. The longer i let the water run it seams to clear up. Do I need to cycle it a lot to get dirt out not sure what to do to fix this?
