Macki
I need to move a washer hot and cold supply that comes through the slab about 12”. It is 12” further away from its source, not closer to it. I suspect there is not going to be enough soft copper that is there already to just cut the concrete and bend it and have enough left to keep it above grade.
What is the best method for making an under slab splice?
Moving this here from the remodel section
Thank you,
Thank you,
