Jmaclicious
Curious, I had to rip out an older shower pan due to it cracking around the drain and I will be replacing it with a heavy duty 175 lb cast iron kohler pan... however the rough in on this new pan drain is 3/4 to 1" to the right of my current position... is it possible I could just lean it that way into the new shower pan so i dont have to jack hammer concrete and dig it out in order to do this? Or should I cut down the pipe a bit and add a fernco fitting for more pliability? I could pull it the 1" and put a block to hold it in place. The pictures are the current position, the 2nd pic is where I need it to be when i pull on the pipe. Id rather not have to do more work than necessary!
Drain is ABS pipe.
Drain is ABS pipe.
