Hello,
What a great forum and after a bit of searching, I'm afraid I'm still not 100 percent sure on my answer so here goes.
Currently, I have this:
I want to knock that wall down and move the drain and water over about 55" (towards me from where I took that pic) to a new island. The island will cover the water lines and drain line but the problem is that the stud in the middle of the loop, is right in line with the edge of the island so the vent pipe on the right in the picture is not going to work. I had a plumber come out that seemed overwhelmed so I was researching the best solution. I know the electrical comes out there so we will have to move that but can we chisel around the vent, cut it just below the top of the cement, cap it/fill with concrete so it's flush (I've read a lot of people do the newspaper thing and while I don't want to chisel the slab, is the correct), then run the drain horizontal with the correct slope to the new kitchen and use an AAV like below? Can we use PEX to move the supply over and leave the existing incoming pipes under the island how they are?
