chris.cavage
Our house was built in '73 and had electric baseboards.
We had a two car garage evidently then.
When they added hot water baseboards and an oil burner in our garage, they divided the garage down the middle with a partition wall to close off the room with the tanks and burner.
The plumber ran the pipes very low below the ceiling - they are always bumped. Sometimes I hit my head off of them also!
I removed the partition wall and want to build a laundry room downstairs finally, so I would like to move the pipes into the ceiling.
We have two zones in our home.
There are 4 total lines that I'd need to move. One is a 3/4 in copper feed line, two are 3/4 in copper return lines back to the burner.
The fourth is a 1 inch copper feed line that makes me wonder a few things.
First of all, the 1 inch feed line runs about 20 feet across my garage ceiling (as all the other pipes do), and then it tee's off into two 3/4 inch lines.
I was going to cut all the lines and use an oxygen barrier pex - then meet them back up with the copper on the other end of the garage.
Why is there a 1 inch copper line? Can I reduce the 1 inch line to 3/4 right away and just tee off for the other 3/4 feed?
I'm assuming they did the 1 inch for a reason: to fill both 3/4 lines that are tee'd. But is it necessary?
One reason I was wondering if I can just use 3/4 pex is because I cannot find a 25 ft stretch of 1 inch oxygen pex anywhere!
Thanks for any feedback. I'm new to these forums and find them great!
One person had already recommended I keep the 1 inch line, but to find the pex I need somewhere.
I was also going to use SharkBite push fittings a various points where using a flame is not the best. The SharkBites are supposed to be ok for hydronic heating uses.
Anyway, I appreciate the advice.
