SwiftMKIII
I am trying to move a washing machine, which will effectively move the machine from one waste stack to another.
1. How to vent the washing machine drain?
2. Washing machine drain
I welcome any recommendations, as the layout of my basement does not allow for finishing with the washer and dryer in their current location. I am intending to move the washer and dryer to a "common" area beside the stairs, and put a bedroom where the current laundry is located.
For future proofing, I am also interested in putting a full bath in the area above the stack I am trying to tie into (beside the stairs). The rough in is there, but I will need some vents tied in when that work is done as well. I assume the bathroom drain vents will tie in similarly to the washing machine vent?
Thanks for any advice you can offer. I am willing to provide additional sketches or photographs of the area if that helps with the advice.
- Air Admittance Valve - I understand this doesn't work with pressurized output, like from a washing machine
- Tie into current vent - This vent is 29 linear feet away, around the perimeter of the basement walls (see floor plan sketch), and vent into a separate waste stack (though I don't think that matters)
- Other Vent - I have looked into wet vents, loop vents, stack vents, etc.; I have no idea how to tie any of these into the existing stack
- Can I tie the washing machine drain, with P-Trap and previously discussed vent, in above the clean-out in the wast stack? This drain will travel about 4', under the stairs in the basement, and tie into the existing waste stack (see Proposed Change).
