MikeKenmore
I recently removed tile and installed new backerboard and tiles in a shower/tub unit. the plumbing pipes were not connected to anything and they moved in and out relative to the tile wall. the old valve is an old school Moentrol. I didn't add blocking to the valve since I didn't know the correct depth and figured that if it worked in the past like it had been, I should be good to go in the future. this is in an old condo building that we rent out.
Now, after installing new trim set, I found that I could not install the screw all the way into the threaded hole of the valve; when I did this, it would turn on the water (presumably because the whole system wasn't secured in the wall). so, I set the screw loose so that I could pull the water on and depress it so that it shuts off completely. it seemed to work at first, but when I went back today (I'm selling the unit, hence the remodel), I found that in filling up the tub, there would be a little trickle of water from the shower head if I pulled the handle all the way out. the trickle would take 5 or so seconds to form, but then would be continuous.
The way to remedy the trickle was to push the screw in a little bit so the water wasn't full pressure, but that's obviously not a long-term solution, especially if/when the inspector comes to look at this.
What am I missing? what am I doing wrong? and how can I fix? I can make access to the wall if needed, but it's really a last resort since I would have to cut in from the hallway.
One thought I had, which is totally not a good idea, was to apply some goop (glue) to the screw and handle so that the screw was no longer loose within the handle. I think there's about 1/4" gap on the screw head to the handle when turned off, so I can't really turn off the water without pushing on the screw itself.
