Radiant heating newbie
I needed everyone'e opinions for new replacement bathroom faucets and shower heads. I do care about durability and reliability and that is the number one requirement. thanks.
What are your thoughts about Symmons? I'm going to remodel two baths that have Symmons valves and in 35 years, they've been pretty reliable. Even though the bodies are probably still good I'm going to replace the shower valves with all new as long as I have to open walls. If money is no object, which would you use?Delta makes much better tub and shower facuets that are easy to repair.... The Delta 1700 series
are the best tub and shower faucet on the market....
all the rest of Deltas lines are basically junk--- their kitchen and lav faucets are mostly plastic with
extra long plastic supply lines that you are not supposed to cut....
Moen sink faucets at any hardware store are probably the best for the money and I keep them on my
truck....,... The Moen tub faucets are ok but not as good as the Delta line..
Basically, Delta has gone to hell over the years by kissing up to California and their lead free codes... which have
made mostly all of their faucets extra cheap and shitty..
Kohler is junk across the board......
American standard is a total joke too...
Ghohe is a high end faucet that has been basically ran out of our town and
very few people carry that line any longer and are impossible to repair down the road...
It all depends on how much money you allow your wife to piss away on fancey high end stuff that
looks pretty today but will eventually fail you.....
I installed and serviced a lot of Simmons valves.What are your thoughts about Symmons? I'm going to remodel two baths that have Symmons valves and in 35 years, they've been pretty reliable. Even though the bodies are probably still good I'm going to replace the shower valves with all new as long as I have to open walls. If money is no object, which would you use?
John
Good quality, but the parts may be hard to acquire.
When I have a choice, I would rather use Delta as they are easy to repair and adjust, and parts are FREE and very easy to acquire
Symmons valves suck and I wont work on them, I even bought the expensive tool kit that is supposed to make the jobWhat are your thoughts about Symmons? I'm going to remodel two baths that have Symmons valves and in 35 years, they've been pretty reliable. Even though the bodies are probably still good I'm going to replace the shower valves with all new as long as I have to open walls. If money is no object, which would you use?
John
of extracting sseats easy but it never worked .... You can get yourself into a lot of trouble if you mess with an old symmons valve
with no one in 100 miles that have parts for you....
Steer clear of them
In the 1980s, I testified against Symmons regarding scalding cases. Both cases were nursing homes.Thanks Mark, but I already have two of them, and they're approaching 35 years old so I can't avoid them right now - and they've been very reliable. I realize that my two examples are simply anecdotal and if only 2 out of 10 of these valves are any good, it's entirely possible I got the two good ones out of ten, which is why I asked this group of learned folks.
BUT, let me say this - regarding the seat tool Symmons provides, you're right about the seat tool being difficult and mostly ineffective on the cold seat. The hot seat uses a large square drive tool that goes through the seat and you can put a ton of force on it to back it out, but the cold seat tool only grips the outer lip of the cold seat, and it galls out the brass lip when you try to spin it out. That happened to me. I contacted Symmons after they sent me the seats and tools for free because I couldn't get the cold water seat out with the supplied tool, and they said if the tool didn't work, use a #8 EZ Out. They sent me a .pdf with a very detailed description on how to replace the seats. I suspect a lot of people had the same problem with seats that were in the valve for 25 years. I picked up a #8 EZ Out as they suggested, tapped it into the seat with a hammer, and backed the cold seat out with a ratchet. Came right out with no slippage. The only trouble I had with the EZ Out was getting the cold seat off the EZ Out tool because I might have tapped it too hard into the seat..I cut into the seat with a Dremel and split the seat off the EZ Out with a screwdriver.
As far as parts, Symmons provides all repair parts for free, but if you don't want to wait, Home Depot carries everything for the Symmons Temptrols right on the shelf including the spindles.
John
Google Symmons shower valves scalding cases
Once there is a problem, I feel it loses credibility. One lawsuit can cost millions. The liability, in my opinion, is not worth it.Is that an issue anymore with mixing valves being required?
John
