JoeThomas
I just installed a new Moen Tub Spout 179101. When installing it, you see a white portion with caulking. Everytime I press down on the spout lightly, I can see the spout separate, and see hole edges between the ring and spout (see green box). Is this the way, Moen Tub spout is supposed to be installed, or did plumber not install it correctly? Pictures may be small, however edges and cracks do occur.
The concern is water leaking through, causing mold/mildew which can be a bigger problem.
https://www.moen.com/products/Monticello/Monticello_Diverter_tub_spout/179101
https://www.homedepot.com/p/MOEN-Decorative-Metal-Diverter-Tub-Spout-in-Chrome-179101/203183724
