Moen Single Handle Faucet Issue
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by DaveJW, Apr 18, 2017.
  1. DaveJW
    DaveJW New Member
    Apr 18, 2017
    Pennsylvania
    I recently replaced a Moen cartridge in an old single handle faucet. (Moen part number #1220). It is working fine with the exception that sometimes it does not shut off completely - almost like the handle doesn't get the cartridge stem all the way back down. Other times it works fine. I'm not sure what is causing this.
  2. hj
    If it is a kitchen faucet , you probably do not have the handle engaged into the fulcrum properly.
  4. DaveJW
    DaveJW New Member
    Apr 18, 2017
    Pennsylvania
    Thank you. I am thinking I may not have the pivot retainer nut tight enough. Was afraid to over tighten. Is there any other "trick" to attaching the handle?
  5. hj
    That is no usually the reason for what you describe.
  6. DaveJW
    DaveJW New Member
    Apr 18, 2017
    Pennsylvania
    I'm not sure what to do to fix the issue.
  7. hj
    Since we cannot see HOW the handle is operating when it does not function properly, neither do we. Can you push the handle down to shut off the last bit of flow?
  8. DaveJW
    DaveJW New Member
    Apr 18, 2017
    Pennsylvania
    Yes. I can push down and that usually stops the flow. Or I can jiggle the handle and get it to stop.
  9. hj
    That usually means the handle is either NOT engaged onto the fulcrum properly, or you have a cracked fulcrum, which is a possibility with certain models of Moen kitchen faucets. but, since we cannot see it, that is just a guess.
  10. DaveJW
    DaveJW New Member
    Apr 18, 2017
    Pennsylvania
    Thanks very much for your help. I noticed on the retainer nut a portion of the rim was bent badly. I replaced the nut and with more detailed instructions from Moen I was able to fix it. If only they included the more detailed instructions with the cartridge, it would have save me a lot of frustration. Thanks again.
Similar Threads: Moen Single
Plumbing Forum, Professional & DIY Advice Can't get Moen single handle faucet off Jun 14, 2017
Plumbing Forum, Professional & DIY Advice Moen Single Handle Pull Down Kitchen Faucet water supply hose question Feb 21, 2017
Plumbing Forum, Professional & DIY Advice Adjust hot/cold on single handle Moen bathtub control? Nov 2, 2016
Plumbing Forum, Professional & DIY Advice Do any of you old timers remember the model name of the original Moen single handle kitchen faucet? Feb 9, 2015
Plumbing Forum, Professional & DIY Advice old Moen single handle kitchen faucet Jul 7, 2013
