Moen shower diverter stuck
David Rohland
Mohnton, PA
The diverter in my shower will not turn at all. I removed the handle, extension, sleeve and bonnet nut. I cannot get the diverter to move at all. It won't turn nor come out. Any suggestions as to how to remove this? I tried turning it with a pliers but did not use too much force for fear of breaking the plastic stem.
WorthFlorida
Solutions
Orlando, Florida
Moen cartridges can be tough to get out. First you must remove the clip but before you do, get a replacement.
HudsonDIY
Hudson, Florida USA
If the cartridge doesn't come right out (which they rarely do). Do yourself a favor and buy the removal tool. They can be found on amazon for less than 10 bucks. It's well worth the small investment to save yourself a lot of headaches.
David Rohland
Mohnton, PA
If the cartridge doesn't come right out (which they rarely do). Do yourself a favor and buy the removal tool. They can be found online for less than 10 bucks. It's well worth the small investment to save yourself a lot of headaches.
I don't see a clip on this.
This is what it looks like from behind.
David Rohland
Mohnton, PA
I dug out all the putty and still do not see any clip. this is a plastic stem and diverter. I still cannot turn it or remove it. Any other suggestions? Here are photos after the putty is removed.
HudsonDIY
Hudson, Florida USA
My apologies, initially I read that Worth identified your faucet as a Moen and ran with it, but this doesn't look like any Moen I've ever seen. Hopefully one of the pros can chime in and correctly ID your faucet.
David Rohland
Mohnton, PA
It is a Moen - at least that is what is inscribed on the sleeves.
WorthFlorida
Solutions
Orlando, Florida
This is about the worse video there is but you might get the idea what this idiot was doing.
