JeffNC
I'm using a T2901BL trim. It says it uses the Posi-Temp and M-PACT valve. Looking at the specification sheet though, it specifically lists valve series 2500 and 62300.
I got the 2326PF valve and it also says it's Posi-Temp and M-PACT. However you can see the model is 2300 series. Looking at a valve from the 2500 series and this valve, as in the links below, the only difference I can see is that tiny notch at the tip of the valve stem. (Aside from the connector type obviously - that's why I got this model in the first place.)
Can anyone tell me if the valve and trim are compatible? I'm trying to get an answer before Moen tech support opens on Monday morning.
Moen | Bathroom & Kitchen Faucets, Shower Heads, Accessories & More
The Gibson collection gives contemporary industrial design a softer point of view. The tubular spout and handles mirror the look of exposed piping while polished edges to create a chic and Modern style.
www.moen.com
Changing the look of your Bath has never been faster and easier. The M-PACT Common Valve System allows you to upgrade the trim style or swap out finishes on your fixtures without replacing the valves. So once the system is in place, you can change your decor as often as you want at any point in...
www.moen.com
www.moen.com
