Moen Posi-Temp, Replacing shower valve
Discussion in 'Shower & Bathtub Forum & Blog' started by Jeff53, Feb 20, 2019.
  1. Jeff53
    Jeff53 New Member
    Feb 20, 2019
    Virginia
    I'm having my shower redone and was thinking about replacing my current Moen Posi Temp valve with a new one while the wall was opened up. My only concern is about the quality of new valves. My current valve was manufactured around 1998 when the house was built. Are the new valves built as well as the older ones? Does Moen still manufacture their valves in the US with quality parts? Should I replace the valve or is it better to just keep the older valve and replace the cartridge? Thanks in advance. Jeff
  2. Terry
    Aug 17, 2004
    If you can replace the cartridge now, I would use the old brass. Though sometimes while it's open it's the best time for replacement. It does seem like the old brass bodies had a bit more volume to the shower heads.
  4. Jeff53
    Jeff53 New Member
    Feb 20, 2019
    Virginia
    Thanks, Terry. I'll grab a new cartridge for it and install it before everything is buttoned up.
  5. Justin Ball
    Justin Ball New Member
    Feb 22, 2019
    San Diego, CA
    It's not the valve manifold that goes bad, but the Moen Posi Temp cartridges. Moen's been making their cartridges in North Carolina since they launched the Posi Temp cartridge back in the 80's. I've seen them made, they're legit. I'd keep the current valve in there, unless you wanted to replace it with an upgraded features, like a valve that has water volume control like the Moentrol valve.
Similar Threads: Moen Posi-Temp
Shower & Bathtub Forum & Blog Moen Posi-Temp Shower water temperature mystery...can you solve it? Apr 29, 2019
Shower & Bathtub Forum & Blog Moen Posi-Temp, Low Flow at tub spout Feb 13, 2019
Shower & Bathtub Forum & Blog Moen Posi-Temp Trim kit needed for bath and shower Oct 7, 2018
Shower & Bathtub Forum & Blog Moen Posi-Temp. please help how to remove part that handle connects to May 3, 2018
Shower & Bathtub Forum & Blog Moen Posi-Temp Stuck Shower Handle Adapter Jan 22, 2018
