Kiko
I've got an old Moen single handle faucet that is single-hole mounted using a deck ring assembly. It has been leaking forever, and I can't remove the nut that connects the sprayer to even get at the mounting nut, because it is corroded so badly. I assume that the mounting nut is just as corroded, and it is buried inside the mounting bracket. This mounting nut would be difficult to get to with a wrench, let alone a grinder or a dremel. I also tried to remove the handle and the spout from the top, but the handle is fused on. Did I mention that the sink is so high up that you have to really strain just to reach the mounting nut, which makes it even a bigger pain.
How would you guys proceed?
