Moen 2600, Hot and cold reversed in shower
Limelate
California
We removed and replaced a Moen 1200 cartridge in our shower (single knob handle, pull to open, push to close). It seemed to go easily but now hot and cold are reversed. (When putting the new cartridge in, we did not notice an up or down (12 and 6) and just pushed it in).We have since turned the stem 180 (it moves easily) but the hot/cold are still reversed. We now, over several days, we have turned the stem 180 several times but, nope, still reversed. We don't mind at all, will not get scorched but have questions:
1) Is it ok to leave it as it is? or something else getting damaged?
2) what's wrong? and does it indicate there is some other problem we need to pay attention to?
3) should we remove and replace the entire cartridge (or get a new one)? When inserting the cartridge is there an up and down?
The 1200 and the 1225 cartridge if spun 180 will reverse. Are you sure you're not turning it 360?
There is no up or down to the standard push/pull Moen cartridge.
The Posi-Temp that rotates to the left to turn on does matter how it's installed.
Limelate
California
Limelate
California
I am sure we turned the stem 180. Since we've now done this several times (reattaching the faucet each time), I'd assume we've gone at least gone 360. the stem does turn easily, even by hand.
Limelate
California
I realized that we have always turned 180 in a clockwise direction. Just re-did going counter clockwise and it worked! thank you tho I still have no clue...
