Mixing Tank - Where to buy?
CCinPA
Central PA
I currently have a mixing tank that I use to inject Sulfuric Acid to lower the output pH. I would like a larger tank so I do not have to refill so often. Any resources for these tanks?
I think what you are describing is a "solution tank".
One possibility would be use the same 15 gallon solution tank that you have now, double the amount of H2SO4 that you add for each filling, and halve the rate that the Stenner peristaltic pump injects. I am not a pro. There may be factors that I don't know.
