Rossn
As part of my remodel, I am looking to add a second shower head to my shower... it will actually use the existing 3 way valve that was intended for body sprayers. The existing Kitek Pex-Al-Pex will also be removed.
In copper, and in PEX, what are the minimum sizes that can be used for the hot water supply?
I am asking about minimum size because it is about a 33' run and currently (5/8" PEX home run) it takes too long for hot water to reach.
Cold water supply pressure at the mechanical room is 60-65 psi.
Thanks for the guidance!
