Lifespeed
I installed a Noritz NRC1111-DVNG in 2012 along with a larger gas regulator, 1-1/8" gas trunk line feeding a 1" branch line, and 1" copper water supply along with a Readytemp external recirculator pump and controller. A backwashing carbon filter followed by water softener (both Fleck 7000SXT) were installed at the same time and have been in continuous operation with the softened water tested periodically to confirm proper operation. The heat exchanger was descaled with vinegar three years ago. I have not been descaling annually as this should not be needed with the treated water.
Recently I noticed the water heater would not light from bathroom faucet flow unless it was fully open. If the cold water handle was opened as well, reducing the hot water flow slightly, the water heater would shut off. This is definitely not the same minimum flow rate it had over it's six year life. I haven't measured the flow of this faucet yet, but I would guess it is more than 2GPM and has certainly been more than adequate to light the water heater in the past, even when partially open.
Any ideas as to what might be going on here? I do have the remote control panel installed in this bathroom, but do not see any error codes presuming they would be indicated on this panel.
