WyeTeeQuestionmark061
Two questions as I'm trying to figure out how to run a drain for a kitchen remodel.
I am not proficient in sketchup, so let's imagine these are actually wye connectors, even if they look like sanitary tees (if you tilt your head and squint hard). Flow is right to left.:
1) Is there a minimum horizontal distance between two vertical-to-horizontal wye connections for drain?
2) Is connecting a run at between 45 and 60 degrees allowed, as the second picture shows? I may have a problem with clearance directly above the main line, so I can't run the drain from kitchen sink to directly above the main line and then drop it down.
Thank you!
Thank you!
