Beads
All thumbs
I have 5 questions to ask of experienced people.
1) Do you like the mini split cleaning kits? I am talking about the bags that hang on the units to catch water and cleaner. If so, what brand?
2) What kind of coil cleaner do you like? I am getting tired of the spray cans and I follow with a tank sprayer to rinse anyway.
3) I have Mitsubishi MSZ indoor units. I'd like to pull out the blower wheels to clean them. I have disassembly instructions that have you taking the blower motor off, lots of electrical components from the right side, removing an unidentified "corner box". Finally, I am instructed to remove the three fixing screws from the left side of the heat exchanger and loosen the set screw for the line flow fan (blower cage), lift the heat exchanger and pull the fan out to the lower left. It seems to me that all I really have to do is remove three fixing screws, loosen the set screw, shift the heat exchanger and pull the cage out. Any comments?
4) I'd like to get the drip tray out to clean that, but I have not yet tried to figure out how to do it and it is not covered in the manual that I have. Any tips?
5) I am having trouble finding high quality small brushes to vacuum the fins in the HX. I bought some small brushes, but the bristles pull off and stick in the fins. Talk about counter productive! I found a Mitsubishi kit listed for this, a "Quick Clean Kit", MAC-093SS-E. Apparently it is, however, not available in the USA. Can anyone recommend some quality, small brushes?
Thanks for reading!
Thanks for reading!
