Al S
Engineer
Hello,
I have a 1955 cast iron hub with a 2 in galvanized pipe in what looks like 3 inch cast iron hub with a lead joint. The hub and pipe are vertical and I am seeking advice as to removing the lead that surrounds the pipe.
I've seen examples of drilling out the joint with dozens of holes using a 1/4 drill. Other examples involved heating the joint with map gas. My concern is whether there is a way to remove the joint without the the packing or hunks of lead falling into the cast iron pipe, given that the cast iron is vertical.
Thank you,
Al
Thank you,
Al
