I've noticed that the little triangle on my meter is constantly turning, slowly but not super slowly, even with everything off. The turn rate is constant. If I turn off the water at the house, it stops. Also, if I turn off the valve at the softener, it stops. So, must be something downstream of the softener. The house is not a mansion, so not many obvious places inside for the leak. The toilets never run.
I've read a bunch of threads along these lines, and everyone wants to blame the toilets first. If there is a leak from the tank into the bowl, wouldn't the valve open and I could hear it? We've had that in the past as the flappers went bad, but not now. Also, the little wheel at the meters runs at a constant rate.
Any suggestions?
Any suggestions?
