Mastic removal - Polisher with Diamabrush or 7" Grinder
Discussion in 'Remodel Forum & Blog' started by Soparklion, Jan 13, 2019.
  1. Soparklion
    Soparklion New Member
    Jul 14, 2016
    Pennsylvania
    I need to remove paint/mastic from ~250 sq ft of concrete. I'm considering a $50 DeWalt diamond wheel on a 7" grinder vs renting a floor polisher and a Diamabrush for ~$140/day. The polisher has a hookup for a vacuum that would hopefully diminish dust...
  2. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    The diamond wheel might gum up pretty quickly. I did a floor where I scraped off as much as I could with the scraper and then finished cleaning it with adhesive remover.
    I think the diamabrush should save enough time the the cost would be worth it, but I have no personal experience with it
    Soparklion likes this.
  4. Soparklion
    Jul 14, 2016
    Pennsylvania
    Thanks. Is there an adhesive remover that you would recommend?
  5. jadnashua
    Many mastics soften when wetted. Is the area someplace where you could get it all wet and let it sit for a bit? If so, it will likely come up fairly easily with a scraper. A steamer might work pretty well, too. You can get scraper blades that fit on a pole. Buy a box of the blades, as they get dull fairly quickly over a concrete surface.
    If you're planning to tile the area afterwards, do NOT use a chemical stripper. In fact, the mastic may have seeped into the pores of the cement, and the only way to get a reliable thinset bond would be to run a scarcifier over it to remove a thin layer. That will also rough it up a bit, also improving the thinset bond.
    The way to tell if thinset will bond to the surface is to spread some water on it. If it beads up, thinset won't bond well. If it gets absorbed in less than about 15-minutes, you should be okay.
  6. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    I bought a gallon of Zinsser adhesive remover, which is what they had at the local hardware store. I really dont have anything to compare it to.
  7. Soparklion
    Jul 14, 2016
    Pennsylvania
    UPDATE: I used a mastic remover from Home Depot on a small section... it dissolved the mastic and carried it into the pores of the concrete.
    So I used a diamond cup wheel. Cacher_Chick was correct that the mastic gummed up the teeth... of the DeWalt diamond cup that has two rows of big, rectangular teeth.
    However, the Harbor Freight diamond cup wheel - comparable to Makita https://www.harborfreight.com/4-1-2-half-inch-diamond-turbo-cup-wheel-98729.html - just chewed through it without much of an issue. I'm not sure how to describe the grinder pattern. I'm downright disappointed by the DeWalt. It also had poor quality control - one of the teeth was 'short' and didn't contact the substrate.
    cacher_chick likes this.
Similar Threads: Mastic removal
Remodel Forum & Blog Bathroom Drain Pipe Removal - Looking for Suggestions Nov 21, 2017
Remodel Forum & Blog Need professional tool for dustless abrasive paint removal, as for lead paint Sep 11, 2017
Remodel Forum & Blog big sink demo/removal Aug 7, 2015
Remodel Forum & Blog Floor Joist Removal Mar 29, 2013
Remodel Forum & Blog Vinyl floor/carpet tile removal Jul 4, 2009
