TWHI
Greetings everyone, thanks for being here for the conversations.
We have a Rheem 9.9gpm ECOH180DVRHLN Tankless water heater with built-in recirculation pump and cross over at the farthest location (EcoNet is not installed.) We have programed the recirculation pump for a schedule but it is not satisfying our erratic pattern of use. The learning mode is not making sense either as it has not been able to adapt.
We are looking for a way to manually start the internal recirculation pump with this unit. A little research has shown that there is a method for adding a push button to start a pump, but it is only for external recirculation.
for reference (https://images.homedepot-static.com/catalog/pdfImages/43/433a47e1-7304-4cf7-9e2d-bdc206ee0858.pdf)
Is there a way we can add the ability of manual recirculation (button) to start the internal recirculation? Might you have another suggestion besides turning off internal recirculation and adding external pump at farthest location? Enabling the eternal recirculation in this unit is not an option as we don't have ability to add the appropriate return loop to this old home.
Thank you in advance.
Service Manual for this model (https://s3.amazonaws.com/WebPartners/ProductDocuments/7496DB1F-380B-46AC-951E-BA17CA39DF8A.pdf)
