Aaron Perez
Hi all,
I have a 2 story house. Had a water leak a few days ago from somewhere on the wall between the laundry room and bathroom. Laundry side has water connection, bathroom side has no water (toilet/sink/shower/tub water sources are on outside wall). Figured it was washing machine's drain piping, but that looked fine. My wife checked bathroom directly above, said that water in the bowl was swirling, but no one had recently used it. She used the toilet and after flushing/filling, no continued filling or swirling.
Yesterday had another leak. No one ran any laundry that do, so unlikely to be any water source from downstairs. Checked toilet upstairs and found the culprit: water in bowl swirling, could hear it filling, pulled tank lid and saw water going over overflow tube. I have since adjusted the fill level but will likely replace the tank internals.
So, question, finally ... life story, I know, but anyway ... what could cause a 2nd floor toilet's continually properly draining overflow tube to leak into the walls? We've been in the house for 2 years and haven't seen any leaks in normal usage until this overflow issue. The toilet never overflowed outside the toilet (no water on 2nd floor). The house was built 2001, not sure if toilets are original but likely. Also, if it matters, toilets are Mansfield.
Just not sure if I have a bigger problem lurking in my walls that I should be getting fixed before it's a serious problem.
