How often should the precharge on a pressure tank be checked? Some people recommend as often as every two months. As far as I can tell some makers don't seem to require/recommend periodic checking. Certainly many homeowners never check the precharge after the installation. Here are some things I found and did not find, looking for data from manufacturers.
http://www.flotecpump.com/residentialpage_resource_faq_tanks.aspx
says "NOTE: The tank pressure needs to be checked AT LEAST twice a year. It is better to check it every-other-month. "
Pentair Southern Cross documentation says "... and then checked approximately every six months."
http://documentlibrary.xylemappliedwater.com/wp-content/blogs.dir/22/files/2013/09/IM252R01.pdf This Goulds instruction manual does not specify to do check the precharge periodically.
http://www.amtrol.com/media/documents/wellxtrol/9015868_MC10185_06_12WXT_PRO_IO_NG.pdf
This Amtrol instruction manual does not specify to do check the precharge periodically.
I don't find similar Flexcon documents. They may keep their installation instructions hidden a bit, or I might not be up to the search.
It may be those makers who specify checking periodically don't hold air as well. Maybe the marketeers keep those instructions/suggestions out of easy-to-find documents. Maybe the technology is such that some tanks don't need air to be added during the warranty period.
Thoughts?
Thoughts?
