Lowering 3/4 hp submersible pump down 100ft
nc73
Miamisburg, OH
Recent test showed good water quality. I'm just concerned with dumping all that water and the other issue being the dump location.
I'm not very well versed on geo, but what is your water quality like? Would an open loop, returning the water to the well be an option?
nc73
Miamisburg, OH
You could use a heat exchanger at the bottom of the Geo loop. It would transfer heat much better than a plastic pipe loop. You could make one out of copper pipe easy enough. Either way, with the heat exchanger or an open loop setup, you will need to bleed enough water from the well to make it work. When you are using water from the well, it is bleeding plenty to transfer the heat/cool. When not using water you could hook up a bleed valve controlled by temperature coming from the loop pipe.
Yeah I was thinking bleed too but again I need a place to dump that bleed water. I wonder what the efficiency is like since I don't have bedrock. Clay isn't that great of a heat conductor.
VAWellDriller
Active Member
Richmond, VA
FWIW the return wells always seem prone to plugging. The hardness in the water will drop out in low pressure situations (like after a CSV), eventually causing the return well to lose acceptance rates and generally making a mess in the yard.
Again, function of water quality, also when we do it, we install a pitless unit and piping inside down below the water level in the return well....that way, you don't aerate the water and cause iron and such to precipitate. Another problem with return wells is that people try to be cheap, and don't install a good well, or develop the well properly. The return well is just as important, so we drill a mirror image, and develop it the same way. A lot of folks try to go shallower, and put it back in another aquifer to save money on the return well.....it never works. I know of lots of return wells that accept in the hundreds of gallons/minute; almost continuous for years, no problems.
Cost for a return well....I'd be about $6000-6500 for a 370' well, fully cased and screened, gravel packed, grouted and developed.
Craigpump
$6000-$6500 sounds more than fair to me, but I know the mentality of most homeowners. If they can't see it and show it off, they probably won't spend the money to have the job done right.
LLigetfa
DIYer, not in the trades
NW Ontario, Canada
The water comes from a porous aquifer under the clay and gets its temp from Mother Earth. My neighbor's 300+ foot rock well produces surprisingly tepid water, not cold like my 65 foot mud well.
DonL
Houston, TX
lol
That is funny but true.
Plus the power savings of putting something in and maintaining it will not pay for itself in a lifetime.
Have Fun.
Craigpump
LL is right about clay being a poor conductor of heat, that's why they have to put so much sand in the grout when grouting in the loops.
