ekrengel
Hello,
We are having an issue with our water pressure. With the water running, I was watching the pressure gauge, and the PSI seems to be staying at around 50-55. My current settings should be as followed:
I thought the pressure control switch might be going bad, but it seems to be turning off the pump correctly (about after a min which has been normal for our pump), so it's not short cycling or anything like that. It doesn't appear that the pressure gauge is "stuck" either because it does move a little bit, but the reading is definitely false because our water pressure is low.
I also did some inspections on the tank...what I checked on the tank:
Does anyone have any recommendations for anything else I should check?...Or what might be causing the bad water pressure or not accurate cut-in/out? I know it could be a whole number of things...but maybe the next logical steps that I can check on my own.
- Cut-in = 40
- Cut-out = 60
- Condensation goes about half way up (I read this is normal)
- Tapped the tank from the bottom up, and had different sound after about half way (that was normal)
