Hi everyone,
I'm not sure if I have a broken toilet or a broken husband, and I'm hoping for some advice regarding the correct toilet bowl water level.
Here's the deal:
We have owned the house for nine years. There are two baths, each with a Kohler toilet.
The upstairs toilet has always had an extremely low level of water in the bowl (barely high enough to cover the hole in the bottom of the bowl). The toilet also makes a big GURGLE noise when flushed and has been known to create a splash that I'd nicely classify as "unpleasant". So, unless it's an emergency I avoid this toilet, because using it is frankly gross (in my opinion). I have had to let go of my annoyance at this for nine years in the interest of marital harmony. I figured at least I had a non-freaky toilet in the downstairs bath.
The downstairs toilet, up until recently, has always had what I consider to be a "normal" water level in the bowl. However, a few weeks ago this toilet developed an issue: after flushing, the filling of the tank just kept running. Husband did some sort of repair (involving duct tape) in the tank. This fixed the "water continually running" issue. BUT...now the water level in the toilet bowl is much lower than it was before. Not quite as low as the upstairs toilet. And occasionally - maybe 20% of the time - the water level even looks close to "normal"....but sometimes this normal looking water level will slowly drop, like the water is just slowly draining out. Honestly though, most of the time it's just low. Also, when I flush this toilet now, the flush handle feels clanky and loose.
Husband's point of view is that as long as the toilets flush, then everything is fine, and the level of water in the bowl is not important as long as everything "works".
Clearly I know next to nothing about toilets and plumbing, but none of this seems right to me. So I guess my question is - can anyone point me in the right direction here? Advice? I looked around online and unfortunately there's not a website with a graphic saying "DUDE, your wife is right about the water level being too low and here's a picture explaining why!"
If you've read this far, THANK YOU, and I apologize for my inelegant descriptions of my toilet woes!
Here's the deal:
