I have a well that runs out of water pretty quick, two quick showers or a med load of laundry and we are out for 30mins to an hour before recovery. I am actually hauling water in and storing in 2-55 gal drums in basement, using a 12v pump and garden hose to be able to do large loads of laundry and for water changes in my fish tanks.
The well is 50' drilled in 1989 and was at 8gpm when tested. A regeneration was done in 2005 and a SymCom pumpsaver plus was added due to burning up pumps from running dry, pump was raised to about 40' if I recall at that time and water tops out at about 11 or 12' I think so about a 30' column of water in a 6" casing. The Pump saver is set to restart every 15 or 20 mins and usually only has to run 1 or 2 cycles before pressure is re-established, we have a 30/50 switch with a 20 gal pressure tank.
So, I've been researching adding a 200 gal reserve tank in the basement with another booster pump. Fill the tank, use out of it, then let well pump fill tank as needed. I am a DIY'er so I have considered buying every thing separate and hooking it up, but this is new territory for me so need some advice.
I am leaning towards doing option number 2 from this thread I found. Leaving the current reserve tank setup, then adding tank after with a new pump to feed house.
https://terrylove.com/forums/index....w-yield-well-pumping-into-storage-tank.62150/
I have looked at this setup, maybe kind of pricey ( ??) but it's a plug and play type setup. My only concern is using the manual float valve on the incoming line. I guess it works, but unsure.
https://www.freshwatersystems.com/p-4335-low-flow-water-package-w-200-gal-tank-and-fittings.aspx
If I was to piece together, then I am kind of in the dark ,but would like to save money if I can, we need a decent softener system also with an O/R as we cannot drink the water currently due to high mineral content. I believe its calcium from the limestone in out area. I am now hauling in drinking water for us and our farm animals. I've found some tanks for around $250-300, but I would have to drill holes and add bungs which is no biggey....expect that outlet bottom drain, how the heck you get that one in and tight? Fishtape? I'm used to doing bungs for my DIY pond drum filters and such, but I don't have 6' arms to reach inside a 8" hole.
Pumps? I am clueless on a decent pump that will work for this application other than those listed on the Fresh water systems site.
I also do not know much about using electric cutoff switch or how to wire it to shut pump off or where to buy a decent one.
So any advice would help. Can I piece this together to save money or should I just buy the Fresh water systems unit and be done.
Thanks
Thanks
