Low pressure with new pressure tank
Keith5486
Elberton, GA
I just replace my well tank with a new one (same aize) as the originals bladder failed. Now I have low pressure out of the hose. Well tank and pump pressurize to 60 psi per the gauge. Cycle on and off at the regulated 40/60. I'll comfirm with an independent gauge later this week when that arrives. It just barely trickles out. Help
WorthFlorida
Solutions
Orlando, Florida
Is it the same if the pump is running? Is it only at a hose spigot or the entire house? Possible debris in in the pipe or the spigot itself. Did you try it without a hose connected? Are there any other spigots?
Did you move or install any check valve or just left it as it was. With an empty tank is the pressure set to 38 PSI?
