Dana, you're correct, I visualized the gas consumption data then when downloading I didn't move the selector to "gas." Below is the natural gas usage and the house walls are poured concrete in the basement (9ft tall 12 inches wide) then red brick that is 10in wide it appears for two stories. The attic is a walk up with no heat but insulated with R15 from the second story. The exterior walls have no insulation to the rooms on the first or second story. The interior walls among the rooms have R20 (just in case we close a room off for storage).
Read Date & Days Read type Total therms Delivery charges Supply charges Late payment charges Total charges
12/9/2019 & 33 Days Actual 349 $71.78 $107.91 $0.00 $175.00
11/6/2019 & 29 Days Actual 134 $58.09 $32.46 $0.00 $87.59
10/8/2019 & 28 Days Actual 58 $49.18 $14.14 $0.00 $60.98
9/10/2019 & 32 Days Actual 25 $34.14 $6.84 $0.00 $39.91
8/9/2019 & 30 Days Actual 16 $28.99 $3.44 $0.00 $31.80
7/10/2019 & 30 Days Actual 23 $33.13 $5.58 $0.00 $37.74
6/10/2019 & 33 Days Actual 74 $51.16 $22.43 $0.00 $71.12
5/8/2019 & 30 Days Actual 128 $58.15 $43.95 $0.00 $99.19
4/8/2019 & 31 Days Actual 268 $71.68 $103.46 $0.00 $168.35
3/8/2019 & 29 Days Actual 377 $80.46 $144.59 $0.00 $215.61
2/7/2019 & 29 Days Actual 438 $86.46 $210.53 $0.00 $286.61
1/9/2019 & 33 Days Actual 395 $88.04 $231.02 $0.00 $309.35
12/7/2018 & 31 Days Actual 338 $74.82 $146.85 $0.00 $212.84
11/6/2018 & 28 Days Actual 174 $61.25 $67.24 $0.00 $122.19
10/9/2018 & 32 Days Actual 68 $50.27 $26.03 $0.00 $71.64
9/7/2018 & 30 Days Actual 23 $32.98 $8.59 $0.00 $39.70
8/8/2018 & 29 Days Actual 23 $32.97 $8.32 $0.00 $39.42
7/10/2018 & 29 Days Actual 26 $34.72 $11.19 $0.00 $43.77
6/11/2018 & 34 Days Actual 65 $51.40 $33.07 $0.00 $79.86
5/8/2018 & 29 Days Actual 185 $60.53 $94.87 $0.00 $148.93
4/9/2018 & 31 Days Actual 327 $69.31 $164.67 $0.00 $231.47
3/9/2018 & 30 Days Actual 311 $72.37 $153.85 $0.00 $226.22
2/7/2018 & 29 Days Actual 377 $76.15 $161.00 $0.00 $237.15
1/9/2018 & 31 Days Actual 483 $77.86 $188.64 $0.00 $266.50
On a side note the boiler is running great. When off it is 12psi at 140F and 16-18psi when 160-175F running. That was an adventure to get going but very educational
We keep the house at 70F and the family uses no external heat sources to compensate in their rooms. (A perfect setup would be to remove the low hanging black iron pipes and raise them one day, any suggestions there would be appreciated. Could copper replace them if funds allow?)
