cturboaddict
I purchased a 1920s home last year that had alot of remodeling already done to it. Bathrooms/Kitchens have all been redone.
My kids rooms and bathroom are on the upper level of the house. Their shower/tub faucet/head water pressure is really really low. Every other item in the home including the upstairs toilet and sinks have good pressure. Just this shower/tub. It doesn't matter if it's it's pouring directly out of the spigot for the tub or the shower head. Both slow. Hot and Cold are both evenly slow. I'm not familiar with these exposed setups.
Now the tub itself looks to not have been swapped during the remodeling before we moved in. And the shower faucet/head is one of those exposed valve setups. (SEE PICTURES)
Shower2
Shower3
Shower1
I climbed into the crawl space and located the copper pipes, which look to be in great condition. There is a "T" right where the stub ups into the bathroom are (under the floor) that feed the sinks and toilet from the same line. There are no shutoff valves at the shower (only ones through the floor for the sinks/toilet). I've tracked the feed lines into the basement and find no shutoff valves there as well. Seeing that every other device that is hooked to these water lines has good pressure, I'm assuming it's got to be the valve/head assembly. So essentially there is a straight shot from cold and hot water to the upstairs shower.
Can anyone help point me in the right direction to track down why there isn't any pressure.
Can this valve assembly be disassembled by taking off the hot/cold levers and possibly refurbished for good pressure?
Shower2
Shower3
Shower1
