Deeiche
Recently I bought a manufactured home on a deep (1500') well, water is high in alkalinity,TDS, bicarbonate/carbonate, sulfate and pH. More about quality here, https://terrylove.com/forums/index.php?threads/advice-needed-well-water-plumbing-and-treatment.67418/ . Pressure switch is calibrated 60/40, works correctly. I static tested 60 psi at manufactured home outside spigots, until you open inside faucet, then water flow almost completely stops at outside faucet.
A spigot right after pressure tank flows 10GpM, a spigot on the line before it enters home is a little over 1GpM. 1.25"PVC exits though floor in pressure tank house, runs about 100' before coming up under house. I did not pull off pipe insulation between ground and house service entrance, so I don't know what dia pipe was run to house.
I'm thinking I may have to run a new service line from pressure tank house to home. What do you recommend for new line?
Suggestions are appreciated. thx
